Building a Graber i3 September 15, 2016 02:09AM |
Re: Building a Graber i3 September 15, 2016 07:44AM |
Re: Building a Graber i3 September 15, 2016 10:07PM |
the_digital_dentist
You want hardened rails for LM8UU bearings or the balls will chew up the rails quickly. If they don't say they are hardened, they aren't. You can cut hardened rails to length using a cutoff wheel on a grinder or a chop saw.
There's always a little slop in LM8UU bearings, so if they used 4, you'd probably better use 4. Alternatively, you can get extra long bearings, but those may not fit the rest of the parts.
Re: Building a Graber i3 September 17, 2016 01:16AM |
Re: Building a Graber i3 September 18, 2016 01:49AM |
