Pololu Electronics as per Adrian Bowyer
Posted by Phobia1
January 22, 2011 08:42AM
Hi Guys an Gals
Does anyone have a proper BOM for the parts list of Adrain's build?
Whilst I have waited 3 months and counting for Gen 6 to be delivered have decided to build my own and perhaps this is a better option.
Best
FJW
[reprap.org]
I need to know the actual specs if someone has made it.
4 100uF CPOL-EUE3.5-10 E3,5-10 capacitors
2 10uF CPOL-EUE5-5 E5-5 capacitors
2 100n C-EU025-030X050 C025-030X050
2 VNP14NV04-E BUZ11BV TO220BV transistor-power
2 4.7K R-EU_0207/7 0207/7 resistors
1 1K R-EU_0207/7 0207/7 resistor
2 MSTBA3 MSTBA3 MSTBA3 con-phoenix-508
Edited 2 time(s). Last edit at 01/22/2011 08:55AM by Phobia1.
Re: Pololu Electronics as per Adrian Bowyer
February 15, 2011 01:05PM
Hi, is it missing a 7805 voltage regulator on your list?
February 15, 2011 05:22PM
It could be, I am not electronics as you can tell from my post. No doubt it got a load of laughs.
I built it in the end and it works perfectly.
Now trying Gen 6 with the 3nd Mendel.
Best
F
February 17, 2011 07:02PM
It's good to know that works, since I'm following the same steps. smileys with beer
February 18, 2011 03:26PM
It does work and is very good. I sold my first Mendel to a close friend, this 2nd I have Gen6.
IMHO the pololu is better though soon they will upgrade the board to have more memory due to more modern requirements.
I shall go back to it next time for certain. My intentions are to follow Dr Adrian Bowyer and Nophead.
Best and good fortune
Frederick
February 18, 2011 04:24PM
Where did you buy the 2 VNP14NV04-E? I found it at mouser (2,84€ +20€), digikey orders start at 1000 units and on ebay i cant find it. Theres no reasonable price.
Edited 1 time(s). Last edit at 02/19/2011 04:46PM by katxu.
March 07, 2011 02:46AM
I am also having the same problem finding the VNP14NV04-E MOSFET's..... Like Katxu said DigiKey has a 1000 minimum order and now Mouser is out of stock until the end of May 2011.
Does anyone know where i can get these individually or is there a similar MOSFET that will work just the same?
March 07, 2011 04:26AM
