Box (case, outer insulation) for Prusa? December 03, 2016 02:53AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 05:20AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 05:35AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 07:38AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 07:43AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 07:45AM |
Re: Box (case, outer insulation) for Prusa? December 03, 2016 08:14AM |
Whatever the filament you want to print requires. The foil is only for insulation.Quote
Fizpok
What temperature of a bed should I set if I use the Mylar foil?
Re: Box (case, outer insulation) for Prusa? December 03, 2016 08:35AM |
