Gears turn but filament will NOT extrude December 08, 2016 02:48PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 02:59PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 03:17PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 03:20PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 03:22PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 03:29PM |
adenton
The makers of the filament recommend between 180 and 210
Re: Gears turn but filament will NOT extrude December 08, 2016 03:36PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 04:53PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 05:24PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 05:54PM |
Re: Gears turn but filament will NOT extrude December 08, 2016 06:02PM |
Re: Gears turn but filament will NOT extrude December 09, 2016 05:09AM |
Re: Gears turn but filament will NOT extrude December 11, 2016 02:16AM |
Re: Gears turn but filament will NOT extrude December 13, 2016 07:33PM |
Re: Gears turn but filament will NOT extrude December 14, 2016 03:04PM |
Re: Gears turn but filament will NOT extrude December 14, 2016 06:09PM |
adenton
Is the best way to increase tension on the extruder to adjust the tension screws? I have tightened them all the way down and it did not make a difference, and I have also removed the springs on the tension screws and tightened them all the way down. Neither of these made a difference. How do I increase the tension enough so the motor skips and the filament isn't chewed?
