Inductive Bed Leveling
December 22, 2016 12:42AM
Hello Folks,
I have installed an inductive sensor on my machine. When moving a metal object under the sensor the LED lights up. My voltage at the 'S' pin on the z endstop is 4.7 volts and 0.2 when I use a screwdriver to trigger the sensor. My ramps board is seeing this change but when I run the M119 command it always shows 'open'. I set z endstop to 'true' in marlin. My software looks good but it does not ever show 'TRIGGERED". I am baffled. Ant help would be great. Thanks
Glenn
open | download - Bed Level Setup 2.jpg (255.1 KB)
open | download - Bed Level Setup.jpg (283.8 KB)
open | download - Bed Level Setup 3.jpg (254.9 KB)
Re: Inductive Bed Leveling
December 28, 2016 05:21AM
Can you move the connection to another one of the endstop pins (all of them if necessary) and check if it shows up as triggered then? Faulty arduino pin is at least a possibility.
December 28, 2016 11:56AM
How have you connected the sensor to the ramps board, most of these sensors will output 12 volts(if connected to a 12 volt supply)
so they need to have a resistor voltage divider or diode fitted to protect the processor port pin.
December 28, 2016 02:08PM
Thanks
I will try those suggestions out. I am using a voltage divider and the board is seeing 4.7 v on the pin.
Glenn
December 28, 2016 02:44PM
Question: You're plugging into the Z Min pin on your RAMPS?
You're going to want to change a couple of things
Comment out:
#define ENDSTOPPULLUPS
Then under the section
#if DISABLED(ENDSTOP PULLUPS)
Uncomment the #define ENDSTOPPULLUP lines for the endstops you're using
Except
#define ENDSTOPPULLUP_ZMIN
Leave it commented out, usually with that type of probe, you need to disable the pullup
That should get it to the point where it at least changes state when you manually trigger it
Lastly if it seems to be TRIGGERED when it's not actually TRIGGERED, but OPEN when it is actually supposed to be OPEN
You may have to invert the logic by changing this line to true
#define Z_MIN_ENDSTOP_INVERTING false
December 29, 2016 03:01AM
It's been a while, since I played with marlin, but wasn't there a section where you had to define that z-min IS a sensor input?
December 29, 2016 09:34PM
I will give those suggestions a try. I am plugged into the z-endpin on the ramps. I have also selected fixed sensor. I will give it a go.
Will let you guys know.
Thanks for the help. You are a good bunch of folks
Glenn
