npn sensor wiring with lm7805 ??
February 09, 2017 11:01AM
I want to wire a npn sensor with a lm7805. Will this work or will i just end up with the blue smoke ?
thanks Nikki
Edited 1 time(s). Last edit at 02/09/2017 11:02AM by Nikki81.
Re: npn sensor wiring with lm7805 ??
February 09, 2017 11:31AM
The 7805 can cause some latency or bouncing. something you don't want to see in a probe-signal. Why not use a resistor divider?
February 09, 2017 12:01PM
You will get some nice smoke if you connect the blue and black together
connect brown to +12v
connect black to i/p of regulator.
but as o_lamp said , a resistive divider has 0 latency.
February 09, 2017 02:50PM
Thanks Ill use a resistor divider i just had a few lm7805s to hand
February 10, 2017 11:01AM
Is this the correct wiring for a npn sensor ?
February 10, 2017 03:53PM
more like this
Dont forget to disable Z pullup on this pin
Edited 1 time(s). Last edit at 02/10/2017 03:54PM by obewan.
February 11, 2017 03:03AM
fantastic i'll get it wired up later on.
Thanks Nikki
February 11, 2017 09:45AM
I have followed your diagram but i am having some problems.
powered up with 12v not activated showing 0.29v
activated showing 2.69v
Edited 1 time(s). Last edit at 02/11/2017 09:49AM by Nikki81.
February 11, 2017 10:37AM
Try with a 33k ohm and a 22k ohm. the others may be loading the probes internal diodes.
