extruder problem March 09, 2017 03:46PM |
Re: extruder problem March 09, 2017 04:59PM |
Re: extruder problem March 09, 2017 05:30PM |
Re: extruder problem March 09, 2017 05:33PM |
Re: extruder problem March 09, 2017 05:40PM |
Re: extruder problem March 09, 2017 06:50PM |
Re: extruder problem March 09, 2017 07:21PM |
Re: extruder problem March 09, 2017 08:34PM |
Re: extruder problem March 09, 2017 09:54PM |
Re: extruder problem March 10, 2017 03:49AM |
gianniskix
At the beginnig it works but after few seconds it stucks.The temperature is correct.The printer when it stucks, not extrude and not reverse.i tried to push it with my hands but it does not move.
Re: extruder problem March 10, 2017 03:12PM |
Re: extruder problem March 10, 2017 03:28PM |
Re: extruder problem March 10, 2017 04:28PM |
Re: extruder problem March 11, 2017 03:33PM |
Re: extruder problem March 12, 2017 11:22AM |
frankvdh
There are a number of causes of extruder skipping.
If the motor is too hot to hold your finger on, you should reduce amps. Another test is to pause the print (keeping the hot-end up to temperature) when the skipping starts. Wait for a few minutes, then resume printing. If the skipping restarts immediately, the problem is in the extruder driver or motor. If not, the problem is in the hot-end. Or, when the skipping starts, cool the driver heatsink or motor or hot-end heatsink (Spraying with methylated spirits (ethyl alcohol) worked for me, but a good blower fan or whatever)... if that makes the skipping stops or reduces, then you've found the culprit.
Re: extruder problem March 12, 2017 06:41PM |
Re: extruder problem March 16, 2017 06:37PM |
Re: extruder problem March 20, 2017 02:30AM |
Re: extruder problem March 23, 2017 09:51AM |
Re: extruder problem March 31, 2017 12:02AM |
Re: extruder problem March 31, 2017 12:09PM |
Re: extruder problem April 14, 2017 02:38PM |
