Upgraded to dual extruders - extruder0 works but extruder 1 won't heat up
March 20, 2017 03:18PM
Hey everyone,
I have a hictop printer 3DP-17 and I just upgraded it to dual Mk8 extruders...
I have updated the Marlin firmware (I edited the configuration.h and added the second extruder ) recompiled it and sent it to my printer.. Everything seems good but it will not heat up extruder1 - extruder0 heats up but it was turning in the wrong direction and pushing out the filament.. I edited configuration.h again and resolved that issue but still no go on extruder1.
I contacted HIC and all they said was that it does support dual extruders but it will not work with auto level bed and filament monitor. I am not using either of those 2 features.
Any suggestions on what I am missing to get extruder1 to heat up? Do I need to comment out the auto level and filament monitor code?
Any help will be greatly appreciated.
M
Re: Upgraded to dual extruders - extruder0 works but extruder 1 won't heat up
March 20, 2017 11:58PM
Stupid questions but:
Did you set the other thermistor in Marlin?
Did you changed the slicer settings so it knows your printer have dual extruders?
Understand that you won't have a filament sensor for the second extruder, but why you will loose the one for the first extruder and why you will loose the ABL function?
