extruder heating problem
Posted by Karzin
June 11, 2017 10:43AM
I have a MK8 extruder, that has a fan mounted on it, if i extrude with the fan off, the filament gets warm and soft and collapses next to the gear and wont go into the little teflon tube. however if i turn the fan on, the extruder temp drops to 170C regardless of the settings in the slic3r (first layer 210C, other layers 205C)
has anyone ever dealt with this?
Re: extruder heating problem
June 11, 2017 12:25PM
The fan isn't supposed to blow on the heater block. Maybe you have mounted it incorrectly.
June 12, 2017 12:41AM
Correct, fan should blow on cooling fins of the hot end, not the heater block.
Images of a MK8 show a fan on heat sink, are the fins up and down or left and right, Should be left and right.
June 12, 2017 10:44AM
Thanks, in my case its vertical. the problem is that it only has screw holes to be mounted this way. but yeah I believe the amount of airflow bouncing form the heatsink is enough to bring it down to 170C. I'll try fixing it smiling smiley
