Ball screw vs lead screw June 24, 2017 08:38PM |
Re: Ball screw vs lead screw June 25, 2017 12:38AM |
Re: Ball screw vs lead screw June 25, 2017 02:23AM |
Re: Ball screw vs lead screw June 26, 2017 03:34AM |
Trakyan
They also tend to have more backlash, but this is not really an issue for the z axis as it doesn't change direction much and has a pretension downwards due to gravity. When it does change direction it is rather slow and small movements and gravity helps get rid of any backlash. If you're paranoid you can make/buy an anti backlash nut, basically two nuts separated by a spring but that can increase the friction, I'd say not worth it.
Re: Ball screw vs lead screw June 26, 2017 10:49PM |
Re: Ball screw vs lead screw June 27, 2017 11:21AM |
Re: Ball screw vs lead screw June 27, 2017 08:51PM |
Re: Ball screw vs lead screw July 02, 2017 10:35AM |
Re: Ball screw vs lead screw July 02, 2017 06:53PM |
Re: Ball screw vs lead screw July 02, 2017 11:32PM |
Re: Ball screw vs lead screw July 03, 2017 08:32AM |
Re: Ball screw vs lead screw August 04, 2017 08:46PM |
Re: Ball screw vs lead screw August 05, 2017 06:01AM |
Re: Ball screw vs lead screw August 05, 2017 12:04PM |
Re: Ball screw vs lead screw August 06, 2017 01:53AM |
Re: Ball screw vs lead screw August 07, 2017 02:35AM |
