The screen is off when the limit switch is pressed July 03, 2017 11:33AM |
Re: The screen is off when the limit switch is pressed July 03, 2017 11:55AM |
Re: The screen is off when the limit switch is pressed July 04, 2017 05:04AM |
Re: The screen is off when the limit switch is pressed July 04, 2017 05:07AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: The screen is off when the limit switch is pressed July 04, 2017 05:36AM |
z axis motors rotate opposite July 05, 2017 06:26PM |
Re: z axis motors rotate opposite July 05, 2017 07:10PM |
Re: z axis motors rotate opposite July 07, 2017 07:13AM |
Re: z axis motors rotate opposite July 07, 2017 10:25AM |
Re: z axis motors rotate opposite July 10, 2017 01:59AM |
Re: z axis motors rotate opposite July 10, 2017 04:09AM |
Re: z axis motors rotate opposite July 10, 2017 10:12AM |
Re: z axis motors rotate opposite July 10, 2017 08:39PM |
Re: z axis motors rotate opposite July 12, 2017 01:06AM |
Re: z axis motors rotate opposite July 12, 2017 01:51AM |
Re: z axis motors rotate opposite July 12, 2017 05:16AM |
Re: The screen is off when the limit switch is pressed July 12, 2017 09:20PM |
Re: z axis motors rotate opposite July 13, 2017 02:15AM |
Re: z axis motors rotate opposite July 13, 2017 03:05AM |
Re: z axis motors rotate opposite July 13, 2017 03:36AM |
Re: z axis motors rotate opposite July 13, 2017 04:01AM |
Re: z axis motors rotate opposite July 13, 2017 09:21AM |
Re: z axis motors rotate opposite July 13, 2017 06:00PM |
Only the bed heats not the nozel even if i set the nozel to heat August 25, 2017 11:00AM |
prusa printer unable to start print September 08, 2017 03:34AM |
