PSU cuts power when Heatbed Thermistor is attached August 20, 2017 07:38PM |
Re: PSU cuts power when Heatbed Thermistor is attached August 20, 2017 09:51PM |
Re: PSU cuts power when Heatbed Thermistor is attached August 20, 2017 09:54PM |
Thank you very much! I do have a few 100k hotend thermistors lying around, will definitely try that!Quote
waitaki
I would disconnect the heatbed thermistor connector that plugs into the mainboard then plug another thermistor into the mainboard (just hanging in the "breeze" above the motherboard) and see what you get -
a 100k resistor would probably do if you are short of a thermo.
If the power supply stays on, you will know what to do next!
