Full Graphic Smart Controller, how to rotate the screen 180deg September 16, 2017 11:51AM |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 03:37AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:53AM |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 07:12PM |
#if ENABLED(NEWPANEL) #if ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER) #define BEEPER_PIN 37 #define BTN_EN1 31 #define BTN_EN2 33 #define BTN_ENC 35 #define SD_DETECT_PIN 49 #define KILL_PIN 41
#if ENABLED(NEWPANEL) #if ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER) #define LCD_SCREEN_ROT_180 #define BEEPER_PIN 37 #define BTN_EN1 31 #define BTN_EN2 33 #define BTN_ENC 35 #define SD_DETECT_PIN 49 #define KILL_PIN 41
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:02PM |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:14PM |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:31PM |
Dust
in pins.RAMPS.h
find
change to
Sadly still cant test it, no ramps boards/repraps at work!
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:40PM |
Re: Full Graphic Smart Controller, how to rotate the screen 180deg September 17, 2017 08:45PM |
