Re: UNOFFICIAL: Top 10 needs of the RepRap community (a bit USA centric)
March 19, 2008 05:46PM
Victor,
Can you really do injection molding with 1 bar or is that 1000 bar?
VDX
March 19, 2008 05:50PM
Hi Forrest,
... got the point winking smiley
Maybe i'll try to make a molding form from aluminium with my CNC-mill and shoot some plastic-parts with the drill-press ...
In the mean-time my older son ordered some StarWars-toys:
Viktor
VDX
March 19, 2008 06:02PM
Hi nophead,
the Drader Injectiweld/Orbi-Tech-injection-press works with 1000 bar pressure!
I think you need at least 5 to 10 bar for a coarse fitting, better some 100 bar, which could be made with a drill-press and metal forms.
This high pressures are most made with small pistons pressed in the fluid plastic - you can calculate the end-pressure by the diameter of the piston and the force you apply with the press.
I think a form made from aluminium with some centimeter thick walls an some cubic-centimeters molding volume should withstand 1000 bar pressure - the guy at Orbi-Tech demonstrated this on every fair i saw him with a small mold-form where the company-logo was molded with different coloured ABS-plastic ...
Viktor
March 19, 2008 07:39PM
Ah yes it must be an English / German thing, the site uses . where we use , and visa versa.
Is that Delrin (Acetal) you are milling?
VDX
March 20, 2008 05:57AM
Hi nophead,
yes, i milled the "Han Solo in Carbon"-thingy out from black DELRIN/POM because it should be REAL BLACK ...
It's my best material - stiff for construction, elastic when used for solid-state-hinges and very good and accurate milling without any coolant in any cutting speed (my millhead runs with 11000 until 25000 RPS and until 50mm per second travelling speed).
The next selection is MgAlxx (Duralum or such) - then with alcohol as coolant.
And sometimes wood and other materials ...
Viktor
