Control board supporting 4 Z motors
January 17, 2018 06:41AM
Hi everyone,
I'm designing a 3D printer with 4 lead screws for the Z axis.
My question is: is there any control board that supports 4 stepper motors for Z axis?
I'd like to have 4 stepper motors driven with 4 different A4988/equivalent drivers. I know I could wire 4 parallel motors to one single A4988 driver but I'm afraid it would be too much current to handle for a single driver. So is there any control board which supports this scenario?
Of course if you have any advice on a better/different approach it would be appreciated too.
Thank you!
Edited 1 time(s). Last edit at 01/17/2018 07:03AM by harlandraka.
Re: Control board supporting 4 Z motors
January 17, 2018 07:34AM
Think carefully before you use 4 leadscrews, because that will over-constrain the bed. Unless the printer is very large, 3 is better.
The Duet WiFi or Duet Ethernet + the DueX5 expansion board supports a total of 10 stepper drivers, with provision to connect a further 2 external stepper drivers. You can configure the firmware to perform true bed leveling using 3 or 4 independently-driven stepper motors. If you use 4 motors, this requires the bed to be flexible enough to twist slightly if that's what the stepper motors command. It is inevitable that a large enough bed will have this flexibility, but a small bed won't (which is why 3 leadscrews is generally better).
If you don't want to do true bed levelling in both X and Y directions, you could use 2 stepper drivers to drive 2 motors each, but you may have issues with the two motors within a pair getting out of sync.
If you don't want to do bed levelling using the leadscrews at all, then use a single motor with a belt and pulleys to drive all the leadscrews.
January 17, 2018 09:53AM
Hi tc42, thanks for the response.
Yes, my printer has a large printbed, I tried with 4 leadscrews because it seemed to be more stable (I hope it really is).
I couldn't find any reseller near me which has the Duet board, are you aware of any other model That supports more than 6 motors?
January 17, 2018 11:31AM
My printer had 2 motors on the z axis and that caused problems when they got out of sync. It also hampered bed leveling. I recommend one motor and link the screws with a closed loop belt. That is what I did and it has made my printer much more accurate.
January 17, 2018 05:52PM
harlandraka
Which country are you in? There is a list of Duet distributors at the bottom of [www.duet3d.com]. You can also order direct from that site.
cwaa
Yes, multiple motors get out of sync, and 4 will be much worse than 2. So you need a way to sync them automatically, such as bed levelling by leadscrew adjustment. That's why I said in my earlier post:
dc42
