Cannibalize one hobby printer to build a "set and forget" machine. February 19, 2018 10:25AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 19, 2018 04:34PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 19, 2018 05:36PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 03:02AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 07:29AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 09:41AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 09:50AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 03:50PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 04:55PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 05:32PM |
atheimer
- I agree with the leveling sensor: dc42's IR sensor is a no brainer (again using it on my p3steel for years now).
atheimer
The bed plate is one source of annoyance still. At this point I feel the bed should be non-adjustable and be fixed. Obviously don't see many machines with that design but the newer mesh leveling capabilities of Duet and other 32bit boards are making this more reliable over having a 100% perfect bed. Eliminating bed adjustment screws that can loosen over time or get bumped seems like a good idea. Has anyone seen a good design for a fixed mount bed? I assume you would build, level it once and locktite it with fixed bolts... At this point I think the traditional springs could be skipped.
atheimer
I used steel GT2 belts for my z-axis and while it performed fine, It's just a bit messy for my taste. It seems to me eliminating "belts" wherever possible will also improve reliability and durability.
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 05:52PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 06:16PM |
the_digital_dentist
The last time I looked, (most) delta printers use belts for the Z axis...
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 20, 2018 07:44PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 22, 2018 08:13AM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 22, 2018 04:13PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 22, 2018 04:33PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 22, 2018 08:22PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 22, 2018 08:50PM |
Re: Cannibalize one hobby printer to build a "set and forget" machine. February 23, 2018 12:36PM |
the_digital_dentist
Does a proper bed really cost so much more than a crappy bed plus all the extra electronics and motors that enable it to be used?
Does all that stuff result in a more reliable machine compared to one that has an actually flat and actually level bed?
