Atmega644p or atmega644a on V1.2 motherboard?
Posted by skysurf76
April 25, 2011 01:10PM
I ordered a V1.2 motherboard from makerbot.com and I'm following the instructions for building it on the wiki, but the wiki says to use a Atmega644p while on the printed circuit board I bought it says 644a next to where the atmega goes on the board. I just need to know which one I should use.
Also I know there are newer electronics but I'm an electrical engineering student and the $500 I have spent on this project has already taught me more than any $1500 dollar class and I wanted to use the old electronics so I could build them all from PCB's and have more individual components to build and play with.
Thanks in advance. smiling smiley
Re: Atmega644p or atmega644a on V1.2 motherboard?
April 25, 2011 05:16PM
Check the data sheets for the two chips, and make sure they are pin compatible, I believe the difference is that the 644p is a low power version of the 644A.
May 01, 2011 05:21AM
The ATmega 644P is less power hungry - 0.25 Watts instead of 0.5 Watts or so. It also has an additional serial port (UART1) and a different signature. For the later, things like #ifdef __AVR_ATmega_644P__ don't work for the 644 (needs #ifdef __AVR_ATmega_644__) and may require some adjustments in the firmware.
So - unless you're willing to fix a few minor things, I'd purchase the 644P. Two or three dollars more for less hassle.
