NEMA motors turn both ways with single direction command May 22, 2018 10:11AM |
Re: NEMA motors turn both ways with single direction command May 22, 2018 09:43PM |
paulkoan
Hi, I just bought a couple of these to replace the existing motors on my printer (JK42HS40-1704):
[www.banggood.com]
I am driving these from a RAMPS 1.4 with A4988 drivers.
The existing motors turn fine, but these ones (once I figured out the coil pairs) vibrate heavily, but they do turn. The weird thing is that given the same command they might turn one way or turn the other way. Or turn a bit one way, then turn back a bit then turn the other way again. I am using octoprint, they are wired to the Z axis and I have Z set to the middle of the range so I am not involving endstops.
So it doesn't seem like a coil pair mix up - I had it wrong in the beginning and they just vibrate.
I don't have any load on there, just a spider coupler to see which way they spin easily.
Any ideas why this would happen?
Re: NEMA motors turn both ways with single direction command May 23, 2018 03:46AM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 08:12AM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 09:31AM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 09:51AM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 11:36AM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 05:49PM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 09:26PM |
Re: NEMA motors turn both ways with single direction command May 23, 2018 09:36PM |
Re: NEMA motors turn both ways with single direction command June 10, 2018 07:20PM |
