Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 01:00AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 02:40AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 03:36AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 10:59AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 12:57PM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 07:03PM |
Vatsal J Tanna
OK guxys, my layer has shifted despite homing after each layer. I'm at my wit's end in here.
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 09:22PM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 10:24PM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 23, 2018 11:12PM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 24, 2018 02:13AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 25, 2018 02:37PM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 27, 2018 01:12AM |
Re: Z axis remains lifted when using homing for x and y axes after each layer May 27, 2018 10:05AM |
Vatsal J Tanna
Upon aluminium bed (which I never heat) I place a sweet box's cut out. On top of this, I stick a label paper (not sure what it is properly called) with a glue stick such that the label paper's sticky side is facing up. This setup is fastened with the use of paper clips. It might be that the setup was not fastened properly during that time. But I seriously doubt it. Since I've oiled the axes and added an extra cooling fan for the arduino, the same bed setup is giving me fine prints. I'm not an expert, so I really don't know what happened.
