Cable management and other noob questions. June 22, 2018 02:52AM |
This PSU is capable of supplying 70 amps on the +12 volt rail, weather the 5 volt rail is loaded or not, and I could certainly run a couple cooling fans off the periphreal connectors, but doing so means the fans are on whenever the PSU is on. Can that be a problem? Is there any way to power the fans from the PSU and still control them from the ramps board? I'm in southern Michigan and so far the only SSR's I can find locally are $45. That's a bit outside my price range at the moment. I could easily enough wire in an on/off switch for the fans, but I don't think that would be much better.|
Re: Cable management and other noob questions. June 22, 2018 08:09AM |
Re: Cable management and other noob questions. June 22, 2018 12:14PM |
Re: Cable management and other noob questions. June 22, 2018 12:59PM |
Re: Cable management and other noob questions. June 23, 2018 06:16AM |
Re: Cable management and other noob questions. June 25, 2018 06:45PM |
Re: Cable management and other noob questions. June 28, 2018 11:49PM |
Re: Cable management and other noob questions. June 29, 2018 07:26AM |
Re: Cable management and other noob questions. June 30, 2018 06:36PM |
