Re: How do you seal your heat block? November 01, 2018 01:05PM |
Re: How do you seal your heat block? November 01, 2018 01:44PM |
Re: How do you seal your heat block? November 01, 2018 03:38PM |
I expect the system to leak and therefore it does.|
Re: How do you seal your heat block? November 01, 2018 06:38PM |
Re: How do you seal your heat block? November 02, 2018 10:36AM |
Re: How do you seal your heat block? November 02, 2018 02:48PM |
Re: How do you seal your heat block? November 04, 2018 06:10PM |
Re: How do you seal your heat block? November 05, 2018 05:21PM |
Trakyan
Not much point in using an all metal heatbreak if you'll wrap the threads with plumbers tape (teflon).
Re: How do you seal your heat block? November 06, 2018 10:48AM |
