MKS TFT32 not communicating with the MKS Base V1.6
September 26, 2019 04:57AM
I have a MKS TFT32 display that is not communicating with MKS Base motherboard.
I have updated and booted the MKS TFT32 to the latest firmware.
The update was successful but when i tried to print ,nothing works.
There are some flashes from the motherboard but apart from that nothing works.
It seems like there is no communication going to the motherboard.
I have already changed and make sure to set the baudrate to 115200 in the firmware but still .
As far as my research, both the firmware display and the motherboard should have the same baudrate.
All the wires is connected but still dismantle.
I wanted to make sure that its working before i put the printer toogether
Also, the MKS TFT32 and Motherboard cant on when the enstoppers are plugged in.
I used the tiaihua micro switch and only plugged it in the -x,-y and -z
When the switches are pushed down then it can on.
My knowledge of 3d printers is not that much and any help will be appreaciated.
