SKR Turbo 1.4 TMC 2130 SPI
March 20, 2020 02:12PM
I have build my first printer. I am facing problem with homing.
X total length = 600 mm
Y total length = 600 mm
Z total length = 600 mm
Bed Size is : 300x300
My first home is good. All the things are in the middle. After that I again do the home then the printer head goes to right side
2nd Problem
SKR 1.4 Turbo with TMC2130 SPI Sensorless Homing Enable. Marlin 2.0.5.1. I did not installed the end stops. Sensorless homing is also not working.
Marlin.zip
I am facing new problem. My individual axis do this when i do individual homing.
X axis go to left (Xmin)
Y axis go to backward
Z axis go to down.
I think these are correct homing for the individual.
But when I click on auto home the printer do this
X axis go to right (Xmax)
Z axis go to down.
What is wrong ?
Re: SKR Turbo 1.4 TMC 2130 SPI
March 23, 2020 07:59AM
you could try klipper firmware with a pi if you don't want to troubleshoot marlin. there is also smoothieware. there must be something in the marlin firmware that needs to be configured but I guess you will need to read the docs a little more. could take a while unless someone with more experience comes to the rescue.
March 23, 2020 08:06AM
Config file is not attached
August 21, 2020 10:58AM
Robotics909
What is wrong ?
Do you resolve the problem?
If your size bed is 300x300, why the x and y total length is 600mm!?
August 21, 2020 02:36PM
Nunocamelias
Robotics909
What is wrong ?
I would assume some space to let the nozzle go off the bed to do a nozzle wipe somewhere else, maybe on the side of the bed (like I do), also, maybe if you have multiple extruders (lieke IDEX), you need space to stash the extra extruder maybe. I don't know. Also having a 600x600 bed is super heavy, expensive and sucks power. Maybe he built the printer way too big and realized he only needed or could use a 300x300 bed max.
But indeed, it raises questions and now you got me curious as well!
http://www.marinusdebeer.nl/
