Question on Tool chain architecture.... June 15, 2011 12:41PM |
Re: Question on Tool chain architecture.... June 15, 2011 06:02PM |
Re: Question on Tool chain architecture.... June 16, 2011 03:44AM |
* If I understand correctly, a typical approach would be to use some 3D design package to design the part and output a .STL file.
* (the mysterious part)...The .STL file goes into a piece of software that translates this into G-codes.
maybe a Gcode postprocessor that modify the Gcode specifically for 3D plastic printers??
how are the extruder specific commands such as "back up the extruder drive a little so it does not ooze at the end of a move" figured out?
* So what is used to translate .STL into Gcodes??
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
