Testing boards and step motors/ Error July 20, 2020 04:01PM |
Re: Testing boards and step motors/ Error July 20, 2020 11:16PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Testing boards and step motors/ Error July 21, 2020 08:55AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Testing boards and step motors/ Error July 21, 2020 09:29AM |
Re: Testing boards and step motors/ Error July 21, 2020 11:10AM |
Dust
"Error:MINTEMP triggered"
the controller cannot see your thermistor, so it reads the lowest temp. (which is open circuit)
possible causes.
Thermistor unplugged.
Thermistor plugged into wrong place.
Thermistor or its cable is broken.
Incorrect motherboard set, so controller is looking at wrong pin.
Incorrect thermistor defined in Configuration.h
Dead ADC pin on controller.
Dust
Also modern firmwares will not allow you to move E, unless the hot end is hot. unless you deliberately disable this.
Hi Ohmarinus, as I am approaching all this stuff just now, printrun was the first firmware I came across (something like, if you don't start somewhere, you are gonna go nowhere)Quote
Ohmarinus
By the way, printrun is pretty old firmware.
Ohmarinus
I'm also curious what you're doing on Craig van Vliet's macbook
Re: Testing boards and step motors/ Error July 21, 2020 11:24AM |
#if EXTRUDERS case 104: M104(); break; // M104: Set hot end temperature case 109: M109(); break; // M109: Wait for hotend temperature to reach target #endif
#if EXTRUDERS //case 104: M104(); break; // M104: Set hot end temperature //case 109: M109(); break; // M109: Wait for hotend temperature to reach target #endif
Re: Testing boards and step motors/ Error July 21, 2020 11:37AM |
Re: Testing boards and step motors/ Error July 21, 2020 11:42AM |
Dust
or you could edit the code in gcode.cpp
Re: Testing boards and step motors/ Error July 21, 2020 12:06PM |
Re: Testing boards and step motors/ Error July 21, 2020 12:35PM |
