hi i recently finished building a 3d printer which uses ramps1.4 and when i started to print i realized that my z axis moves too much for each layer (about 5mm - 10mm high). I set the the first layer height and other layer heights to 0.4mm
the first layer is always fine but the others are not . I use a T8 lead screw and a 17hs1352-p4130 stepper motor for my z axis.
Edited 1 time(s). Last edit at 11/01/2020 11:03PM by yoonus_rox.
