Is this resistor suitable as a heater for the hot-end? March 30, 2021 10:43AM |
Re: Is this resistor suitable as a heater for the hot-end? March 30, 2021 10:48AM |
Re: Is this resistor suitable as a heater for the hot-end? March 30, 2021 02:58PM |
Re: Is this resistor suitable as a heater for the hot-end? March 31, 2021 11:03AM |
Re: Is this resistor suitable as a heater for the hot-end? March 31, 2021 12:07PM |
the_digital_dentist
The heater block is aluminum. You could drill it out to 6mm in about 3 seconds with a hand drill.
Re: Is this resistor suitable as a heater for the hot-end? April 04, 2021 12:07AM |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 04:49AM |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 06:19AM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 06:56AM |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 11:13AM |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 03:44PM |
Well, yes actually. Ignoring the 30W resistor which is a red herring, a 3W resistor will use about the same length and diameter of nichrome wire as a 30W cartridge heater.Quote
................. Let's consider the construction of wire-wound resistors for a moment. Do you think a 3W resistor uses the same diameter nichrome wire that a 30W resistor (or a 30W heater cartridge) .....................
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 05:17PM |
Re: Is this resistor suitable as a heater for the hot-end? April 10, 2021 10:32PM |
leadinglights
I will be interested in how well your silicone resistor holds up although I am a little skeptical as the vitreous enamel ones can be driven to a red heat for some time before failing but I don't think that the outer insulation on a silicone one would take it as well.
Re: Is this resistor suitable as a heater for the hot-end? April 11, 2021 02:40AM |
Re: Is this resistor suitable as a heater for the hot-end? May 05, 2021 09:51AM |
leadinglights
Re: Is this resistor suitable as a heater for the hot-end? May 05, 2021 02:30PM |
Re: Is this resistor suitable as a heater for the hot-end? May 05, 2021 09:10PM |
leadinglights
For simplicity, and because life is too short to argue, I think that you should use a heater cartridge.
Re: Is this resistor suitable as a heater for the hot-end? May 08, 2021 06:55AM |
Re: Is this resistor suitable as a heater for the hot-end? May 08, 2021 09:29AM |
