Hi, about a few months ago i took out my 3d printer which i had kept away for a while and started to 3d print with it. everything was fine and it would print well. that is unitl recently when i started having problems with my y axis. whenever i home the y axis it moves the wrong direction by a few mm and stops and when i move the y axis using pronterface it would only move one direction and not the other.
the printer uses a ramps1.4 board with a4988 stepper drivers
just to mention again it was working fine until recently, so i dont think that its an issue with a firmware.
i tried connecting the y axis stepper motor to the x axis in the ramps board just to see if the stepper was ok and it worked fine
i changed the stepper driver to a newer one and still had the same issue
i checked if the driver was heating up but it wasnt
can someone pls help
Edited 1 time(s). Last edit at 12/02/2021 08:12AM by yoonus_rox.
