Updated to latest firmware cannot heat nozzle
July 27, 2023 03:12PM
I have updated to lateset firmware and had to use RRF config tool to remake config file I cannot turn on Nozzle heat gives me M568 P0 A2 the M568 command is no longer needed how do I turn oh the nozzle heater
Configuration file for Duet WiFi (firmware version 3)
; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Jul 27 2023 13:22:04 GMT+0200 (Central European Summer Time)
Edited 1 time(s). Last edit at 07/27/2023 03:13PM by sgtmrcooperusmc.
Re: Updated to latest firmware cannot heat nozzle
July 28, 2023 02:48AM
It sounds to me that you are still running an older firmware version. Send M115 to check the firmware version.
July 28, 2023 04:27AM
I get error when start up cannot find heater7
July 28, 2023 04:29AM
7/28/2023, 4:28:34 AM M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
July 28, 2023 04:40AM
I get this code when installing update firmware Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found
July 28, 2023 04:52AM
You were correct It was not flashed with 3.0 I found the IAP.bin file uploaded it and installed FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-11-30 19:36:12 to current firmware ver
now everything works correctly
Thank for the help
