Crealty CR20 Pro woes
Posted by stewils
February 22, 2024 07:19AM
Good Morning,
I'm trying to get a 3D printer up and running (CR20 Pro).
Problem 1:
It dosn't get picked up by windows (10 or 11) when plugged into the USB.
I figured a firmware update is probably in order.
I've downloaded the Marlin, copied across the Marlin config example for the CR20 Pro and downloaded Arduino IDE. At this point Arduino IDE asks for a board. I have no clue. Searches for a RAMPS 1.3 file have gotten me no where.
I'm probably not even looking for the correct thing.
Problem 2:
I've manged to hook up to the printer with Octopi and that works wonderfully, how ever the printing seems to happen about 3 cm above the bed, i.e. not at all.
I've downloaded the instruction booklet and try to follow the setup steps, but the menus I have a different to the ones in the instructions.
The auto home takes me to Z +15
When I move to 'drags on a piece of paper' height and try 'Set Home Offesets' it says Err: Too far!
I have tried with positive and negetave "Probe Z Offset" values (a positive z offset seems to result in a negative z axis and vice versa) but have had no joy.
Current printer driver information:
Marlin, bugfix-2.0.x
Ramps 1.3
Protocol 1.0
PSU Generic
I'm kind of hoping a new firmware update will sort it out. Any help appreciated.
Thanks in advance.
Ste
Edited 1 time(s). Last edit at 02/22/2024 09:09AM by stewils.
Re: Crealty CR20 Pro woes
February 22, 2024 05:05PM
The controller is a Creality V2.1 this uses a ch340 usb serial converter
You need to install drivers for windows to see this [learn.sparkfun.com]
February 23, 2024 08:29AM
Thanks for that!
I'm not sure I'd have ever found that smiling smiley
Now I just have to solve problem 2!
