Keep in mind you can decouple these designs:
How you mount the bed, be it kinematic with 3 studs or 4 or be it fixed or whatsoever, is not necessarily dependant on how you mount the bed undercarriage.
E. g. here the bed is mounted in 4 places but the undercarriage is on 3 leadscrews:
In the end it is all about stability. If you are using CNC parts and you can properly align everything I would go for 4 linear shafts and 4 leadscrews like here, as you also have a quite large build volume (notice they are moving the gantry here though, the bed is fixed):
As far as I understood your design you are asking for an mount like in that picture but with 2 leadscrews instead of 4 (while still using 4 linear shafts). If you have a generally rigid construction I think that may work just fine. Keep in mind to position the linear shafts as close as possible to the leadscrews - so they would be on the sides center, just besides the leadscrew, in your design. If you intend to print very heavy parts (idk, maybe you print 100% infill with metal-filled filaments) I would go for at least 3 if not 4 leadscrews or switch to two beefy linear rails instead of four closely positioned linear shafts for more rigidity considering momentum around the axis from one leadscrew mount to the other.
Mounting the bed in the undercarriage with three points of contact is beneficial considering its alignment, if done properly (kinematic mount, e. g. used in optics for lenses or on laboratory positioning tables). However, if your bed is quite large (just like yours) that would require it to be comparably thick for the unsupported corners to stay flat under load, which adds weight, which may lead to the point where it's more viable to have a fixed bed and move your gantry in Z. So considering your size I would go for a 4 mount bed while still following the kinematic mount principle, just use two instead of one screw for the roll axis. More hassle to align properly but more stable and lighter.
EDIT: It is also very important to mechanically couple the leadscrews imho. The printers in the pictures do that via a closed belt and pulley system you cannot see direcly, utilizing a single motor for Z. You can use multiple motors though (idk, maybe because you have limitations considering drivers or space) - but couple them mechanically so they stay in sync. Every industrial printer I know has that coupling - despite the fact most consumer machines don't, mainly for budget reasons while still gaslightning you into "auto alignment due to independant Z motors" marketing-wise.
Best regards, Demo.
Edited 3 time(s). Last edit at 03/19/2024 07:54AM by Demolux_D1.
