I believe the A2 is a prusa clone, so here goes..
I've been struggling through my first 3D printer, and am finally at the point where I can start to get a good print. My current issue is I have to feed the filament by hand, or the extruder motor is too slow. When I feed by hand, I get a nice thick extrusion with a clean line. When I let the extruder do the work, the filament barely moves and comes out far too lightly.
I'm slicing the files with Cura.
Any suggestions are welcome.
EDIT: I have verified the distance on the printer. I marked the filament against a hard surface as a reference, then jogged the motor forward and reverse and measured 10 mm in both directions (which is what the display read).
Edited 1 time(s). Last edit at 12/18/2018 03:16PM by Jaycen.
