Auto bed leveling for Folger tech Prusa i3? January 07, 2015 01:29PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 07, 2015 04:42PM |
cheaptrick2
Hello there! I have recently got my Folgertech prusa i3 up and running, and I am a very happy camper. I have seen the amazing upgrades, and I want to install an automatic bed leveling system. I have no trouble with printing the parts, and ordering the servo motor, however I need to know where I can find a servo mount file or kit for their strange closed off-injection molded-direct drive extruder. I have seen forums of oeople with automatic bed leveling systems for a Folgertech prusa i3, but where is the correct file for this type of extruder? If someone would help my that would be great!
Thanks everyone!
Re: Auto bed leveling for Folger tech Prusa i3? January 07, 2015 04:49PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 07, 2015 06:39PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 11, 2015 09:50PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 12, 2015 02:51PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 12, 2015 10:01PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 14, 2015 12:12PM |
Re: Auto bed leveling for Folger tech Prusa i3? January 14, 2015 12:57PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 08, 2015 09:46PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 11, 2015 05:06PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 11, 2015 10:16PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 12, 2015 07:08PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 12, 2015 09:29PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 12, 2015 09:55PM |
Re: Auto bed leveling for Folger tech Prusa i3? February 12, 2015 10:03PM |
Re: Auto bed leveling for Folger tech Prusa i3? March 27, 2015 08:29AM |
Re: Auto bed leveling for Folger tech Prusa i3? March 27, 2015 02:01PM |
Have you installed the jumper on Ramps 1.4 to power your servo. Google search is your friendQuote
crspencer00
Hi there,
I am trying to set up this feature on my folger tech i3 and I have a sg90 servo that is properly jumped and wired in according to ZenMaster. The config.h file is also edited. When I plug in the USB to my computer, I get the device connected sound, then immediately the device disconnected sound. The servo twitches and this does this about 10 times before the device permanently disconnects. Has anyone else had this problem? Do I have a bad servo? Thanks!
Re: Auto bed leveling for Folger tech Prusa i3? April 10, 2015 06:34AM |
Re: Auto bed leveling for Folger tech Prusa i3? April 12, 2015 10:13PM |
Re: Auto bed leveling for Folger tech Prusa i3? April 14, 2015 03:17AM |
Re: Auto bed leveling for Folger tech Prusa i3? April 21, 2015 03:04PM |
Re: Auto bed leveling for Folger tech Prusa i3? May 27, 2015 12:10PM |
Re: Auto bed leveling for Folger tech Prusa i3? May 28, 2015 04:02PM |
Re: Auto bed leveling for Folger tech Prusa i3? September 29, 2015 01:14PM |
Re: Auto bed leveling for Folger tech Prusa i3? September 29, 2015 02:39PM |
bugman72
I'm having some issues in getting my autolevel to work. I'm running Arduino 1.6.5, RAMPS 1.4 board (FolgerTech i3 Acrylic) and the latest download of Marlin. I have gone through Zennmaster's videos on getting everything set up and have successfully acquired my servo's extend and retract values as well as extruder offset values. I can successfully run a G28 and the probe works great to home Z. But, if I try a G29, the Z axis will start from where it homed on G28 instead of raising the Z axis before probing (#define Z_RAISE_BEFORE_PROBING 15). This causes a HUGE issues, as there really isn't any room from homing during G28 for the probe arm to swing down to proper position. Thus, the Z axis continues to lower until I have to do an emergency stop to keep the nozzle from hitting the glass bed. I have read all sorts of things to try out and none of these options seem to work. I will include my config.h here, in case there's something I'm missing (which is entirely possible).
I guess it should be worth mentioning that home on my machine is near-left, if facing the machine. I am using a standard micro-switch as my Z endstop/probe and have removed the micro-switch from an endstop board and wired up the new micro-switch to it. This way, I can tell when the switch is depressed by seeing the red LED turn on.
srcga
Thanks for this thread! Having this in my config.h fixed my issues.
#define DISABLE_MAX_ENDSTOPS
Re: Auto bed leveling for Folger tech Prusa i3? September 30, 2015 10:57AM |
Re: Auto bed leveling for Folger tech Prusa i3? May 14, 2016 08:04PM |
