My first printer Geeetech i3 Pro (review so far) March 17, 2015 06:45PM |
Re: My first printer Geeetech i3 Pro (review so far) March 18, 2015 05:00AM |
Re: My first printer Geeetech i3 Pro (review so far) March 18, 2015 02:37PM |
Re: My first printer Geeetech i3 Pro (review so far) March 20, 2015 03:08PM |
kingnyx
Would you mind sharing how you got all the software and calibrations done and what you used for your config.h?
Re: My first printer Geeetech i3 Pro (review so far) March 20, 2015 03:24PM |
Re: My first printer Geeetech i3 Pro (review so far) March 20, 2015 05:39PM |
AndrewBCN
BTW the firmware in the printer can be Repetier or Marlin, but not repeater. And the software on the PC is called Repetier-host or another software Pronterface.
Interesting review but it would be very much enhanced if you added some pictures.
Re: My first printer Geeetech i3 Pro (review so far) March 22, 2015 12:37AM |
Re: My first printer Geeetech i3 Pro (review so far) April 06, 2015 10:08AM |
Re: My first printer Geeetech i3 Pro (review so far) April 10, 2015 01:16AM |
Re: My first printer Geeetech i3 Pro (review so far) April 10, 2015 12:14PM |
Re: My first printer Geeetech i3 Pro (review so far) April 10, 2015 07:07PM |
Re: My first printer Geeetech i3 Pro (review so far) April 10, 2015 07:29PM |
Re: My first printer Geeetech i3 Pro (review so far) April 22, 2015 09:22PM |
Re: My first printer Geeetech i3 Pro (review so far) April 26, 2015 02:26AM |
Re: My first printer Geeetech i3 Pro (review so far) April 27, 2015 12:55PM |
Re: My first printer Geeetech i3 Pro (review so far) April 27, 2015 07:51PM |
Re: My first printer Geeetech i3 Pro (review so far) May 05, 2015 09:37PM |
Re: My first printer Geeetech i3 Pro (review so far) May 05, 2015 10:02PM |
Re: My first printer Geeetech i3 Pro (review so far) May 10, 2015 10:32AM |
Re: My first printer Geeetech i3 Pro (review so far) May 10, 2015 10:51AM |
Re: My first printer Geeetech i3 Pro (review so far) May 11, 2015 02:14AM |
Re: My first printer Geeetech i3 Pro (review so far) May 13, 2015 10:20PM |
Re: My first printer Geeetech i3 Pro (review so far) May 15, 2015 07:52AM |
Re: My first printer Geeetech i3 Pro (review so far) May 15, 2015 12:55PM |
Re: My first printer Geeetech i3 Pro (review so far) May 16, 2015 03:50AM |
I think my z threaded rod got bent a little bitQuote
Laopa
Sarf2k4
The old extended part can fit on the X carriage.
For the wobble, you must fix a guide rod at each extremities, it will be your guide.
The threaded rods, cannot be touching the motor axes. Even inside the couplers.
The top side of the threaded rod must be free and touch nothing. Cut them short.
The plastic clip clamp, first loose the belt, then fix your clamps. If not your belt force will bend your guide rods.
For the glue stick, it is water base, so use hot water.
Re: My first printer Geeetech i3 Pro (review so far) May 17, 2015 09:42AM |
Re: My first printer Geeetech i3 Pro (review so far) May 17, 2015 08:51PM |
Laopa
Hi
For the infill, it is part of machine calibration.
Follow this link which is for me a very good one.
[wiki.solidoodle.com]
And with this you can also adjust your X,Y and Z dimensions.
For pets with mechanical strength, better increase the wall thickness, top and bottom to 4 layers. The infill can be 15 to 20%.
Re: My first printer Geeetech i3 Pro (review so far) May 19, 2015 10:10PM |
Re: My first printer Geeetech i3 Pro (review so far) May 19, 2015 10:37PM |
Make sure you connected the thermistor cable into the correct port. You get that error because the thermistor isn't connected to your 'default' extruder thermistor inputQuote
XYZM
Hey so I have been having a problem where it says "Extruder switched off. MINTEMP triggered !"
Did anyone with the have this. I am using the Gt2560 board.
Re: My first printer Geeetech i3 Pro (review so far) May 20, 2015 11:38AM |
