Re: My first printer Geeetech i3 Pro (review so far) May 20, 2015 08:39PM |
XYZM
I did make sure of that.
The GT2560 has two extruder connections, I tried both and the same result. I will try measuring voltage and resistance at the hotend.
Re: My first printer Geeetech i3 Pro (review so far) May 22, 2015 01:50AM |
Re: My first printer Geeetech i3 Pro (review so far) May 22, 2015 03:03AM |
Re: My first printer Geeetech i3 Pro (review so far) May 22, 2015 03:10AM |
Laopa
Hi
I had some direct request for the modification's on my GEEETECH, i prefer post them here directly for everyone with pictures.
For the Bowden: i have a XL motor attached at the back of the printer on the power supply, still have 2 screws left for this. No need to drill your acrilyc.
The filament enter at the bottom of the motor, guided in the PET TUB untill the E3D on the carriage
with this i can print very nice pièces at 60mm/s in ABS.
In Bowden, i use XL motor , It have a speed reductor, and have more smooth filament delivery. The motor must run 5 times faster to send the same amount of material that the direct extruder.
when running, if you take your filament between 2 fingers, near the direct drive, you will feel small vibrations due to the stepper motor not running fast enough but with steps. so your print will have some small surface waves.
For the Direct drive: When i want to print Flex or PET filament (soft), i remove the PET tub and the fast PET tub plug (in black on the X cariage), place the GEEETECH motor on the X carriage, the filament enter directly on the top of the GEEETECH.
In the GEEETECH motor, i have placed a small device Under the wheels to ensure the filament pass through without jaming. and Under a small PET tub to guide the filament until the E3D.
Check the pictures for more explanation's.
Re: My first printer Geeetech i3 Pro (review so far) May 22, 2015 03:45AM |
Laopa
Hi Sarf2K4,
a 0.1mm caliper is also OK. you have a 0.5mm nozzle. so for this you must get walls at arround 0.5x1.2=0.6mm.
For you Wobble problem, a thread rod is never straigth. even if looks ok with eyes.
You say you have 1 to 2mm waves, but in fact you have wave half of this, because the position will be moving left to right everytime you increase the high of the layer.
i explaine myself: at start, the first layert is uncenter to the left side by 0.5mm, then you up Z by 0.5mm , now your print is centered. you up again next layer 0.5mm now you are uncenter to the right side, next layer up 0.5mm and so on...... A M8 rod have pitch of 1mm, so it is for that you have waves of 1 or 2mm if your layer high is 0.5mm. will be less if you print at 0.4mm.
Do as follow and you will (i wish ) remove this problem.
Pic1: Fix with tooth pic the left smooth rod. This will be your fix mechanical guide. the right side can have very little play, if too much fix it also.
Unscrew the 2 stoppers (in green) and push them in contact on the plastic with light pressure, and tight them again.
Pic2 and 3: Cut your threaded rod to have space on the top and at the bottom. this is where is your problem.
At bottom, you have a MAX limit , do not over pass this or your sprint will be usless.
At top, you can see i have drilled hole much bigger and still have the wobble problem. Cut it short.
X belt, must be tighten "like guitar cord" , not that thight but nearly, do not asked me what key it play
reduce in your config the jerk value to 15 or 10.
TRY your machine.
if you still have problem, then you can reduce the voltage on the drivers. CARE less voltage you will miss steps but TOO MUCH will have spring effect = wobble and over heat.
Measure voltage ~0.6 Volts between GND pin and directly over the potentiometer. care not shot the other pins...
try print at 40mm/s, it must be OK. if not better give us your configH and pic of your machine...
For nozzle cleaning, this is what we do on injection machine and it is very clean. take your nozzle with metal plier, and place it over the gas oven to burn all the plastic outside and Inside. for 4mn. it will became black but after with brush easy to clean. Inside clean with needle.
For PTFE Tube, for 1.75mm filament, your tub must be diameter 4mm outside and 2mm Inside. If bigger, then you will have problems printing and your filament will became a spring Inside your tub, and it will be out of extruder not smoothly, but by steps.
Good luck
Re: My first printer Geeetech i3 Pro (review so far) May 22, 2015 01:34PM |
Re: My first printer Geeetech i3 Pro (review so far) May 23, 2015 09:08AM |
Laopa
Hi sarf2k4
If you go direct drive, the 1 mm gap is not a problem because the distance between the feeder and the nozzle is short.
The filament is strong enough to avoid spring effect.
There is a part can be printed to avoid wobble without cutting short the threaded rod, I will post them soon when I will redraw it. And can be used later for auto bed leveling!
Re: My first printer Geeetech i3 Pro (review so far) May 23, 2015 12:05PM |
Re: My first printer Geeetech i3 Pro (review so far) May 24, 2015 07:17AM |
Laopa
Hi sarf2K4
Your top Z threaded rod is good like that. be sure the rod never touch the white plastic part when it spin.
my E3D is not center because my direct drive is on the left, opposite as yours. also to avoid the extruder getting out of the bed too far when homing.
Ripple is due to jerk (you can even down it) or speed too high or belt not tight enough.
for direct extrusion the retraction must be ~0.5 to 1.5mm and speed of 300, 4.5mm is good for Bowden.
Better attached your wires on the carriage, or pretty soon your connection will became lose or your contact will be cut.
Gear grinding, if it is not your retraction it may be you are feeding too fast. did you do the extruder speed calibration? ask it to feed 100mm and measure if it give you 100mm?
Here are the parts to also avoid wobbling and picture for example. I have also modified one hole to install the automatic bed leveling following this guy test.
[www.thingiverse.com]
Re: My first printer Geeetech i3 Pro (review so far) May 25, 2015 03:54AM |
Re: My first printer Geeetech i3 Pro (review so far) May 25, 2015 04:29AM |
Re: My first printer Geeetech i3 Pro (review so far) May 27, 2015 04:31AM |
Re: My first printer Geeetech i3 Pro (review so far) May 27, 2015 09:57AM |
Re: My first printer Geeetech i3 Pro (review so far) May 27, 2015 10:04AM |
Re: My first printer Geeetech i3 Pro (review so far) May 27, 2015 08:56PM |
Laopa
Hi SAF2k4
I will not touch the tread rod, it will not solve your wobble after all you have done, but I will have a look at the smooth rod and the bearings.
In GEEETECH, the bearing are very cheap and often "missing some balls inside". and the smooth rods, who are not stretch rod but grinded.
-You better measure your rod diameter and they must be at 7.98mm minimum. In my first post that was my frst problem, my rods where at 7.94mm.
-when you have your slider bearing on good rod, it cannot spin!!!!!! if it can spin, then you have some play and you cannot control the position.
also cheaper way to try first, use my Z wobble part previous message, if this do not solve, then measure your rods.
good luck
Re: My first printer Geeetech i3 Pro (review so far) May 28, 2015 11:03AM |
Re: My first printer Geeetech i3 Pro (review so far) May 29, 2015 04:19AM |
Laopa
Hi
Look up I have a post with " Z Anti wobble support". Those parts remove the connection from thread rods and the rest of the machine. Have a picture.
Sorry but I never try PLA, but as all plastic I would try first a parts going up and changing the temperature down every 5 layers to find my material temp.
You have some tips on Internet about temperature control parts. cube 1 wall 20x20 but with hight of 100mm. And modify code to change temperature.
Re: My first printer Geeetech i3 Pro (review so far) May 29, 2015 12:43PM |
Re: My first printer Geeetech i3 Pro (review so far) May 30, 2015 09:25AM |
Re: My first printer Geeetech i3 Pro (review so far) May 31, 2015 02:59AM |
Re: My first printer Geeetech i3 Pro (review so far) June 01, 2015 01:32AM |
Re: My first printer Geeetech i3 Pro (review so far) June 01, 2015 01:07PM |
sarf2k4
@dhmclean
Are you sure that you used the correct layer height with your threaded rod size? If you are using an m8 thread rod paired with 0.24mm, that is not an optimal layer can be seen here [prusaprinters.org]. Because 0.24mm I think are suitable for something like imperial type threaded rod, not metric based
Re: My first printer Geeetech i3 Pro (review so far) June 01, 2015 09:25PM |
Laopa
HI Sarf2K4
Good you finaly solve that.
I just Wonder who can sell you a Rod with Inch thread
Re: My first printer Geeetech i3 Pro (review so far) June 02, 2015 06:52AM |
Re: My first printer Geeetech i3 Pro (review so far) June 02, 2015 09:51PM |
"Extruder switched off. MINTEMP triggered !" June 06, 2015 12:39AM |
Re: My first printer Geeetech i3 Pro (review so far) June 06, 2015 07:30AM |
Re: "Extruder switched off. MINTEMP triggered !" June 06, 2015 07:39AM |
Cycleguy
Hello I see you have a number of posts so I presume you are well beyond this issue but how did you fix the ""Extruder switched off. MINTEMP triggered !" concern? I have the same controller board now but my printer kit is not yet assembled so I've not yet used it. I did read that there is a setting in Marlin where I'll need to have a minimum temperature reached or the extruder will not be allowed to "turned on" to feed filament. It makes sense or the motor could not force the filament through the extruder. Was that the issue in your case or was it an actual issue with the GT2560? Any advice would be appreciated as I am reading all I can trying to avoid issues in advance.
Re: My first printer Geeetech i3 Pro (review so far) June 10, 2015 01:36PM |
Re: My first printer Geeetech i3 Pro (review so far) June 10, 2015 08:57PM |
So far so good on my end despite printing at around whooping 60mm/s producing ripple effect on every edgesQuote
RRuser
I see that these Geetech i3 units are acrylic frame. Does anyone have experience on if they will warp or crack?
Also, is the SD card ribbon cable routed near other things which may cause interference? Some printers put the SD card directly on the controller board so that there is no ribbon cord to collect noise.
