Disadvantages of acrylic frames March 29, 2015 11:44PM |
Re: Disadvantages of acrylic frames March 30, 2015 04:42AM |
Re: Disadvantages of acrylic frames March 30, 2015 12:08PM |
I'd disagree depending on what you are using it for. For something like the Prusa i3 where the acrylic is for the gantry support, the forces that the acrylic are acted upon are in such a way that the rigidity of the sheet isn't necessary. It also isn't subject a significant amount of heat as a gantry.Quote
Zavashier
Otherwise, it's maybe one of the worst material for any machine building. It's not stiff, it's fragile, it's not stable under heat...
Re: Disadvantages of acrylic frames March 30, 2015 12:50PM |
Re: Disadvantages of acrylic frames March 30, 2015 12:56PM |
Re: Disadvantages of acrylic frames March 30, 2015 01:35PM |
RRuser
I see that some Prusa kits have the option for acrylic, aluminum, and steel.
Re: Disadvantages of acrylic frames March 30, 2015 01:44PM |
Re: Disadvantages of acrylic frames March 31, 2015 02:09AM |
Re: Disadvantages of acrylic frames March 31, 2015 06:31AM |
Re: Disadvantages of acrylic frames April 02, 2015 11:56PM |
Re: Disadvantages of acrylic frames June 28, 2015 12:08PM |
Re: Disadvantages of acrylic frames June 29, 2015 02:23AM |
Re: Disadvantages of acrylic frames June 29, 2015 08:16AM |
Re: Disadvantages of acrylic frames June 29, 2015 01:20PM |
RRuser
Makes sense. Acrylic and heat don't mix, certainly not long term. Would love black metal options for all the i3 printers.
Re: Disadvantages of acrylic frames July 05, 2015 12:51AM |
Re: Disadvantages of acrylic frames July 05, 2015 02:51AM |
Re: Disadvantages of acrylic frames July 05, 2015 04:00AM |
o_lampe
I highly doubt, that the y-table has to be made from 3mm steel?! 3mm carbon fibre would work better, right?
Re: Disadvantages of acrylic frames July 06, 2015 01:57AM |
Re: Disadvantages of acrylic frames July 09, 2015 07:47AM |
Re: Disadvantages of acrylic frames July 09, 2015 03:20PM |
o_lampe
Carbon fibre is light enough to be used without all the fancy weightsaving holes and cutoffs. Just a plain 22x22cm plate, made from prepreg carbon.
Then put it in the oven and drill a few holes.
Carbon is just an example, but IMHO a lot of materials would be better for the y-bed, than 3mm steel.
Probably a steel frame wouldn´t need these full-height triangles, that are mounted perpendicular to the frame? They could be made shorter, so they could be made from the material, that is now used to make the y-bed?
[OT
]In the delta forum I asked about using CF as heatbed material, too. Carbon/graphite is conductive and we would have the lightest, stiffest printbed.
-Olaf
Re: Disadvantages of acrylic frames July 10, 2015 04:48AM |
Re: Disadvantages of acrylic frames July 13, 2015 12:20AM |
Re: Disadvantages of acrylic frames July 14, 2015 11:22PM |
Re: Disadvantages of acrylic frames July 15, 2015 08:23PM |
Re: Disadvantages of acrylic frames July 16, 2015 08:00AM |
Re: Disadvantages of acrylic frames July 16, 2015 09:36AM |
RRuser
Maybe there is a minimum thickness that solves most acrylic problems. Aren't printers using 8 mm now?
Re: Disadvantages of acrylic frames July 16, 2015 04:55PM |
Re: Disadvantages of acrylic frames July 17, 2015 11:52PM |
Re: Disadvantages of acrylic frames July 18, 2015 05:29AM |
Re: Disadvantages of acrylic frames July 18, 2015 08:11PM |
