MakerFarm 12" Prusa I3V - my build, usage, and mods April 26, 2015 08:35AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods April 27, 2015 12:57PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods April 27, 2015 01:36PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods April 29, 2015 09:18PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 02, 2015 05:58AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 02, 2015 06:04AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 02, 2015 08:53AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 02, 2015 12:46PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 02, 2015 09:10PM |
lokiwizz
Yes, I to feel your pain. Only seems to happen when i try to post from my phone thoughQuote
itchytweed
Note to forum: I am not a bot. Your algorithms are stereotypical fail.
Look forward to your build log
Chris
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 05, 2015 07:17AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 06, 2015 01:18AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 07, 2015 12:59AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 07, 2015 01:20PM |
itchytweed
Word to the wise... the heated bed on this beast draws 34 amps at 14.2 volts. Luckily, I have a 50 amp supply. Finished up making the wiring neat and some wire tie manufacturer is rubbing their hands just a bit more...
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 07, 2015 02:41PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 08, 2015 03:23AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 08, 2015 08:05AM |
o_lampe
OK, Im glad to hear that.
If it is a solid state Relais, in fact it is a semiconductor already.
If it is a mechanical relais, be aware, that they tend to "stick" when they actually should switch "open".
I hope you`re using Marlin with the "thermal runaway" option enabled...
Olaf
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 08, 2015 08:06AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 09, 2015 09:43PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 10, 2015 09:43AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 11, 2015 09:19AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 11, 2015 12:47PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 11, 2015 02:19PM |
milkypostman
The glue stick works well but I just tried the blue painters tape and it's way better with less mess. I had a hell of a time getting the excess glue off. I didn't have a scraper though.
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 12, 2015 07:49AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 14, 2015 08:50PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 17, 2015 11:09AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 19, 2015 05:11PM |
itchytweed
BTW, my version of the RUMBA board looks to have a separate COM port connection: RX, TX, GND and +5. Wonder if my FTDI USB to RS-232 will play on there? No drawings show the port and neither do the pictures on the wiki.
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 20, 2015 12:05AM |
ReSiStAnCe
itchytweed
Have a look at the schematic of the Arduino Mega 2560 http://www.arduino.cc/en/uploads/Main/arduino-mega2560_R3-sch.pdf]found here[/url] or the RUMBA schematics http://www.reprap.org/mediawiki/images/2/24/RRD-RUMBA_SCHEMATICS.png]here[/url]
The RUMBA is really an Arduino-Mega2560 reference design with some addons on one board..
The 16U2 is just an 'interface' between the USb port and the ATMega, just like the FTDI is.. The serial data is then connected to TXD0 nd RXD0.
So if these pins are are indeed available your FTDI should work..
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 20, 2015 12:35AM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 20, 2015 03:29PM |
Re: MakerFarm 12" Prusa I3V - my build, usage, and mods May 22, 2015 04:25PM |
