Hi
Good to see your progress,
From the print, the outside perimiter lines, we can still see they are 2 lines , mean you can still down a little your nose.
After this you have no choices, you must do flow calibration, print the same part until you see gaps between lines. At first layer. And increase again little.
And after thsi will be temperature and speed.
Good work
