how do i wire my psu to my heated bed June 17, 2015 04:36PM |
Re: how do i wire my psu to my heated bed June 17, 2015 09:18PM |
Re: how do i wire my psu to my heated bed June 18, 2015 05:34AM |
sarf2k4
Are you serious running a 3d printer with heated bed at 20a psu? Also are you sure to wire up the heated bed directly to the psu?
2 things about my questions above
1. Heated bed can pull up to around 15a during heat up depending on the wire length and its size
2. Heated bed will heat up and continue to burn itself the moment you turn on that psu and thus will melt/burn your heated bed. (an analogy, pressing the gas to the floor when starting engine without letting it go)
Re: how do i wire my psu to my heated bed June 18, 2015 10:00AM |
Re: how do i wire my psu to my heated bed June 18, 2015 10:02AM |
o_lampe
sarf2k4
I have never heard such a BS...
This 200W PSU is easily able to power a common 100W heated bed. ( 8.3Amps @12V )
Back to the question:
Many people power their heated bed directly from the PSU, but they use a relais switched by the controller ( RAMPS, or whatever ) to keep the desired temperature.
Just wire the relais to the heat-bed port and the thermistor to the appropriate temp-probe connector.
Then use bang-bang mode or slow PWM in your firmware and you´re done.
-Olaf
Re: how do i wire my psu to my heated bed June 18, 2015 08:29PM |
Re: how do i wire my psu to my heated bed June 22, 2015 09:49PM |
