Retraction issues June 30, 2015 06:51PM |
Re: Retraction issues June 30, 2015 08:42PM |
Re: Retraction issues July 01, 2015 04:43AM |
Re: Retraction issues July 01, 2015 09:09PM |
sarf2k4
Is that some kind of gcode preview on the 'preview mode' of your picture? What program?
I found the ultimaker troubleshooting guide very useful to find the right parameters.
My retract speed is higher ( 60mm/s ) and also longer ( 4.5mm ), but that depends on your hotend.
I also raise z-axis after retraction about 0.2mm. Don´t know, if that´s an option in your host-sw?
-Olaf
Re: Retraction issues July 01, 2015 10:22PM |
Re: Retraction issues July 02, 2015 10:09AM |
Re: Retraction issues July 02, 2015 01:25PM |
o_lampe
Are you sure, you have your belt tension right?
You can try to print it very slow or reduce x+y acceleration ( say from 9000 to 6000mm/s^2 ) , but with the same retract settings. See if that helps.
-Olaf
What settings would give me less extrusion at the beginning, more at the end?
Re: Retraction issues July 02, 2015 01:31PM |
