Aluminum or Acrylic i3 July 13, 2015 11:35AM |
Re: Aluminum or Acrylic i3 July 13, 2015 11:41AM |
Re: Aluminum or Acrylic i3 July 13, 2015 11:53AM |
Re: Aluminum or Acrylic i3 July 13, 2015 02:34PM |
Re: Aluminum or Acrylic i3 July 14, 2015 07:35AM |
Re: Aluminum or Acrylic i3 July 14, 2015 10:58AM |
Re: Aluminum or Acrylic i3 July 14, 2015 11:43AM |
Re: Aluminum or Acrylic i3 July 14, 2015 01:16PM |
Re: Aluminum or Acrylic i3 July 14, 2015 04:05PM |
Re: Aluminum or Acrylic i3 July 15, 2015 03:39AM |
vegasloki
A stock i3 or i3 Rework can produce good parts. The issue with regards to frame and assembly flex/vibration isn't so much the material of the frame (though that matters), it's the fact the design is only attached to that frame in two places, as with a single plate design or in the case of the Graber style acrylic or melamine frames four points. The objective is not so much stiff material, as it is a stiff structure. A design with a larger footprint and more attachment points using a less rigid, lighter material can be used as the integrety of the design is in the sum of the parts.
Re: Aluminum or Acrylic i3 July 17, 2015 10:05AM |
Re: Aluminum or Acrylic i3 July 20, 2015 08:39AM |
Re: Aluminum or Acrylic i3 July 24, 2015 08:54AM |
Re: Aluminum or Acrylic i3 July 24, 2015 09:30AM |
Re: Aluminum or Acrylic i3 July 24, 2015 10:17AM |
klausbfrederiksen
Then there is the matter of leadscrew upgrades. I have not found a solution that supports both X & Z leadscrews.
I have found 1 Y-axis leadscrew upgrade: [www.thingiverse.com], but which steel I3 does it fit ??
/Klaus
Denmark
Re: Aluminum or Acrylic i3 July 24, 2015 11:09AM |
