Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 12:22PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 03:57PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 04:18PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 04:34PM |
tadawson
The LCD should be nothing more than uncommenting two (and only two) lines in Configuration.h - one for SD card support, and the other for the Reprap discount graphic controller. Myself, I'd be hard pressed to get a video out of that . . .
- Tim
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 09:27PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 09:55PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 10:44PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 10:46PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 16, 2015 10:58PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 18, 2015 07:31PM |
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table // //// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup) #define TEMP_SENSOR_0 5 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 6 // Actual temperature must be close to target for this long before M109 returns success #define TEMP_RESIDENCY_TIME 10 // (seconds) #define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one #define TEMP_WINDOW 1 // (degC) Window around target to start the recidency timer x degC early. // The minimal temperature defines the temperature below which the heater will not be enabled It is used // to check that the wiring to the thermistor is not broken. // Otherwise this would lead to the heater being powered on all the time. #define HEATER_0_MINTEMP 5 #define HEATER_1_MINTEMP 5 #define HEATER_2_MINTEMP 5 #define BED_MINTEMP 5 // When temperature exceeds max temp, your heater will be switched off. // This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure! // You should use MINTEMP for thermistor short/failure protection. #define HEATER_0_MAXTEMP 270 #define HEATER_1_MAXTEMP 245 #define HEATER_2_MAXTEMP 245 #define BED_MAXTEMP 200 // If your bed has low resistance e.g. .6 ohm and throws the fuse you can duty cycle it to reduce the // average current. The value should be an integer and the heat bed will be turned on for 1 interval of // HEATER_BED_DUTY_CYCLE_DIVIDER intervals. //#define HEATER_BED_DUTY_CYCLE_DIVIDER 4 // PID settings: // Comment the following line to disable PID and enable bang-bang. #define PIDTEMP #define PID_MAX 256 // limits current to nozzle; 256=full current #ifdef PIDTEMP //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature // is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. #define PID_INTEGRAL_DRIVE_MAX 255 //limit for the integral term #define K1 0.95 //smoothing factor withing the PID #define PID_dT ((16.0 * 8.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the temperature routine // If you are using a preconfigured hotend then you can use one of the value sets by uncommenting it // Ultimaker #define DEFAULT_Kp 22.2 #define DEFAULT_Ki 1.08 #define DEFAULT_Kd 114 // Makergear // #define DEFAULT_Kp 7.0 // #define DEFAULT_Ki 0.1 // #define DEFAULT_Kd 12 // Mendel Parts V9 on 12V // #define DEFAULT_Kp 63.0 // #define DEFAULT_Ki 2.25 // #define DEFAULT_Kd 440 #endif // PIDTEMP
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 18, 2015 11:08PM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 July 18, 2015 11:39PM |
tadawson
Actually, you know *DEFINITELY* that it is shorted . . . .100,000 ohms is what you should see - 1.4 or so is the resistance of your test leads and your thermistor wires. Check the screw on the hot end holding the thermistor in - K suspect that you will find one of the fibreglass sleeves has shifted.
- Tim
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 October 22, 2016 07:30AM |
Re: Marlin Firmware on Folger Tech 2020 Prusa i3 October 22, 2016 10:29AM |
