How tight to make the Wades hobbed bolt August 13, 2015 06:41PM |
Re: How tight to make the Wades hobbed bolt August 13, 2015 10:40PM |
Re: How tight to make the Wades hobbed bolt August 14, 2015 02:27AM |
Re: How tight to make the Wades hobbed bolt August 14, 2015 02:53AM |
o_lampe
The worst design error on my wade´s is:
The number and thickness of washers between bearing and big gear have to be a perfect match.
Otherwise, after tightening the nuts like Andrew described, the hobbed part isn´t in line with the filament guide, causing low feed force.
So I decided not to tighten the bolt but leave some air for it to center itself by pressure from the filament-guide. Then align the small gear on the stepper and the herringbone gears keep the hobbed bolt at the right place. ( More or less )
-Olaf
Re: How tight to make the Wades hobbed bolt August 14, 2015 11:48AM |
Re: How tight to make the Wades hobbed bolt August 14, 2015 12:34PM |
