I just assembled a Euroway Prusa I3X. It has a dual 12V output PSU and a GT2560 board.
The first time I powered it on (after rechecking all the connections) the LCD flashed on then immediately went black.
Now when I power it up nothing happens at all. If I hook it to USB then the LCD lights up, and I can access all the menus. It still doesn't activate the steppers or the fans, but I can heat up the bed and extruder. I've checked the PSU, and I have 12V on both V+ legs. The power LED on the GT2560 board lights up. When I plug in the USB the other LED on the board lights up. I checked both of the tiny fuses and they're passing voltage. If I disconnect the USB then the LCD goes dark regardless of whether I have the power switched on.
Any clue what I'm missing?
Tony
