Whats Wrong with the Prusa i3? October 25, 2015 03:06PM |
Re: Whats Wrong with the Prusa i3? October 25, 2015 06:49PM |
Re: Whats Wrong with the Prusa i3? October 26, 2015 03:32AM |
Re: Whats Wrong with the Prusa i3? October 26, 2015 04:49AM |
Re: Whats Wrong with the Prusa i3? October 26, 2015 08:05AM |
Re: Whats Wrong with the Prusa i3? October 26, 2015 10:48AM |
Re: Whats Wrong with the Prusa i3? October 29, 2015 08:16AM |
Re: Whats Wrong with the Prusa i3? October 29, 2015 10:53AM |
Re: Whats Wrong with the Prusa i3? October 30, 2015 09:47PM |
Re: Whats Wrong with the Prusa i3? October 30, 2015 11:26PM |
Re: Whats Wrong with the Prusa i3? December 05, 2015 09:07PM |
Re: Whats Wrong with the Prusa i3? December 06, 2015 08:11AM |
Re: Whats Wrong with the Prusa i3? December 06, 2015 02:02PM |
AudaciousTuddle
Sorry for the really late response, but here's pretty much what im hearing from you.
1. Spool holder
2. consider mounting point of Y belt on sled
3. 3 point bed leveling
4. geared drive with light stepper
5. inherently square/level geometry
6. auto-leveling for the last .1mm
7. single Z motor
8. full metal hot-end
9. solid belt tensioner
10. 24V system
11. lighter extruder (bowden)
12. full enclosure for printing engineering plastics
13. use acme rods, and backlash compensation
14. easy to scale build volume
15. Easy extruder conversion
16. built in cooling fan
17. use RAMPS
18. better electrical connectors
19. stiff frame
20. better end-stop system
21. better Z movement system
22. leave room for accessories on the other side of the X carriage.
23. Make sure that Y axis is stiff enough
24. design in wire-management
25. include solder-less wire connectors
Like I said earlier in the thread, I was planning on designing my own prusa spin off (eventually), here's what i'm thinking:
1. its still going to look, feel, and act like a prusa i3
2. a laser cut steel frame, that is inherently square, and level.
3. built in cable guides
4. All solder-less connectors, with different types for different applications in order to seperate them better.
5. M10 guide rods for Y axis, M8 for X and Z. (note, this might change, I haven't run any calculations yet to see if these will be stiff enough)
6. replace linear bearing with tight fitting bushings
7. 200mmx400mm print bed, two of the standard 200mmx200mm plates with a 200x400 piece of glass.
8. replace the X and Y belts with M8 with 8mm lead acme screws
9. replace the Z axis threaded rods with M8 with 2mm lead acme screws
10. some sort geared extruder
My intent is to make a printer that is inherently more reliable and accurate than the traditional Prusa i3. I am aware that the larger print-bed will greatly slow down print-speed, but to me the trade-off is worth it.
Re: Whats Wrong with the Prusa i3? December 06, 2015 08:32PM |
Re: Whats Wrong with the Prusa i3? December 08, 2015 11:22AM |
Re: Whats Wrong with the Prusa i3? December 08, 2015 01:45PM |
Re: Whats Wrong with the Prusa i3? December 08, 2015 05:06PM |
