Prusa i3 Build Plate Offset Issue......Please Help November 12, 2015 08:40AM |
Re: Prusa i3 Build Plate Offset Issue......Please Help November 12, 2015 03:22PM |
// Travel limits after homing #define X_MAX_POS 220 #define X_MIN_POS 0 #define Y_MAX_POS 220 #define Y_MIN_POS 0 #define Z_MAX_POS 180 #define Z_MIN_POS 0
// Travel limits after homing #define X_MAX_POS 20 #define X_MIN_POS -20 #define Y_MAX_POS 200 #define Y_MIN_POS -20 #define Z_MAX_POS 180 #define Z_MIN_POS 0
Re: Prusa i3 Build Plate Offset Issue......Please Help November 12, 2015 03:24PM |
Re: Prusa i3 Build Plate Offset Issue......Please Help November 13, 2015 10:55AM |
AudaciousTuddle
This is the section of the config file you need to change.
it might look something like
You could probably measure exactly how much it needs to move, but I would just use Kentucky-windage to get it more or less in the right spot. I would also watch it very very carefully as its moving to make sure you dont break anything.
Another option is to simply move your end-stops until it homes right in the corner of the print plate.
// Travel limits after homing #define X_MAX_POS 220 #define X_MIN_POS -11 #define Y_MAX_POS 220 #define Y_MIN_POS -41 #define Z_MAX_POS 180 #define Z_MIN_POS 0
Re: Prusa i3 Build Plate Offset Issue......Please Help November 16, 2015 09:27AM |
G28 ; home all axes G29 ; auto level G28 ; home all axes G1 Z5 F5000 ; lift nozzle
