Probably an easy fix but something i've overlooked...
Posted by muntahunta
December 04, 2015 05:21PM
the wing nuts that allow me to level my heatbed keep coming undone due to the vibrations that the printer gives off... messing up the level of the bed. is there any way to stop this?
Re: Probably an easy fix but something i've overlooked...
December 04, 2015 08:31PM
I use M3 hex head bolts and nylock nuts
December 05, 2015 08:15PM
I would go with SteveRoy's option, but another option is to get it level, then add a SMALL DROP of superglue/loctite or a dot of hot-glue to the wing-nut.
December 06, 2015 08:14AM
The nylocks work great for me. No bed movement in months, and no auto leveling needed.
I even have two slightly different thicknesses of glass, and I still don't level the bed when changing them (the thicker glass just gives a wider first layer trace width).
December 06, 2015 07:06PM
I added a small drop of glue to the wingnut and it seems to be working. this will do the trick until i can get my hands on some nylocks.
thanks guys.
