Hi Guys,
i've bought
Replikeo the Prusa i3 and build it up (successfull) /Mechanics.
Yesterday i put all the wires on the Board and flashed the Board with Marlin (1.1.0 RC2) after i setup all the configs.
Now i've tryed to move the axis without any success...
I also tryed to turn on the Heatbed and the Hotend and i've got this Message here.
Connecting...
start
Printer is now online.
echo:Marlin 1.1.0-RC2
echo: Last Updated: 2015-09-28 12:00 | Author: (none, default config)
Compiled: Dec 10 2015
echo: Free Memory: 5313 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo
teps per unit:
echo: M92 X80.00 Y80.00 Z4000.00 E600.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z2.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X2000 Y2000 Z20 E100
echo:Accelerations: P=printing, R=retract and T=travel
echo: M204 P3000.00 R3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo
ID settings:
echo: M301 P22.20 I1.08 D114.00 C100.00 L20
echo:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
Setting hotend temperature to 185.000000 degrees Celsius.
Setting bed temperature to 60.000000 degrees Celsius.
Error:Heating failed, system stopped! Heater_ID: 0
[ERROR] Error:Heating failed, system stopped! Heater_ID: 0
Error
rinter halted. kill() called!
[ERROR] Error
Disconnected.
Here is my Ramps 1.4 Board with Mega 2560 (i hope you can something)
drive.google.com]
drive.google.com]
And my Power Supply 12V 33A
drive.google.com]
Did somebody know what i did wrong?
