Problem Replikeo temperature sensor
Posted by godysseus
January 03, 2016 07:35PM
Hello,
I´m still working for a week to solve a problem but I can´t clear the issue.
My problem is I´m always getting a MINTEMP Error.
I have the Replikeo Prusa i3 kid (I bought it in december) with 1 extruder and Marlin 1.1.0-RC2.
My temp settings are:
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 1
#define TEMP_RESIDENCY_TIME 10
#define TEMP_HYSTERESIS 3
#define TEMP_WINDOW 1
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define BED_MAXTEMP 150
I´ve tested all temperature sensor settings but exept of 110, 998 and 999 I always get mintemp error.
With 110 I get a temperature of 300 degrees.
The thermistors have a resistance so I don´t think they are broken (especially respond because so both sensors (extruder and bed) equal).
Any Idea what I did wrong or what I could do?
Thank you very much.
BR
Georg
Re: Problem Replikeo temperature sensor
January 04, 2016 07:54AM
Does it matter in which direction the parts are soldered? (on the picture attached)
I ask because the left and the right are the same, but the font of the middle is reversed.
open | download - 4,7k.jpg (66.4 KB)
January 04, 2016 06:04PM
Here you can find all stl files to print backup Parts and mutch more important the configs with the temperature sensor values. winking smiley
[github.com]
PS: It dosen't matter what is + or - on a sensor like this. winking smiley
Edited 1 time(s). Last edit at 01/04/2016 06:05PM by DeathmannX.
January 05, 2016 07:42AM
Everything seems to be OK (configuration.h attached), hardware I have now split again and connected everything new.
I worked with LCD and without.
I worked with the power supply and without (only the arduino was connected to usb, no external power) (does that make any difference?).
The temperature sensor has about 100k ohms @ room temperature.
But it still don´t work.
Should I still buy a new Ramps board to give it a try it?
A new Arduino I already trie, did not help.
I have no good ideas any more :-(
open | download - configuration.h (41.2 KB)
