How to get the Aurora RepRap Prusa 3D printer to work on a Mac?
Posted by brianbulfer
January 11, 2016 01:07PM
Can anyone help with getting my Aurora 3D printer to work on my Mac?
I just finished assembling my Aurora 3D printer, I downloaded the repeater-host software on my mac, but there is no communication between the 3D printer and the repeater-host software. When I press the button to connect I get two messages:
-Attempting to connect to printer
-Couldn't open port for device None
What am I doing wrong? How do I open the port to this device? Am I missing a step? How do I go forward?
Re: How to get the Aurora RepRap Prusa 3D printer to work on a Mac?
January 11, 2016 05:58PM
I only used a host program for my first axis movements. After that I have been printing with SD cards and Octoprint so this isn't my forte. That being said you need to be concerned with primarily two things:
1) Make sure the baud rate is the same of that in your firmware.
2)Make sure your computer recognizes the printer.
Both of these options are under the config menu in the host. To change baud rate use the drop down menu. To identify the printer port click "refresh ports" without the printer plugged in. Take note of ports avalible. Then plug in the printer and refresh again. That is the port of the printer.
See Arduino.cc if you cannot see the port.
Personally I would recommend using a Raspberry Pi and Octoprint or the even cheaper 12864 style lcd.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
